Atheros supports 802.11ac. Check out the link below.
Both QCA986x and WCN3680 are currently sampling
Mikrotik. Are you working on making support for the 802.11ac in version 6.1? Are you working on support for the card right now?
Dallas
Dallas
We push 200+mbps TCP average. We want mikrotik. We are being forced to use airfiber. I would like to keep using mikrotik as the backhauls. I keep telling my boss 802.11ac is coming out for mikrotik with the atheros card. I will be your beta tester. I will do what ever is needed to make it work.
Mikrotik, whats the status?
Nice. Have you tried the card with mikrotik yet?
no ![]()
I am going to try to get pricing with them. You should try too.
I’m interested in this as well. I am also still waiting for seamless roaming.
I though I used seemly roaming already with mikrotik. Use HWMP+ for mikrotik which is called Mesh. Works well. Easy to setup. Make sure you have your infrastructure setup properly. Its in the docs.
It worked… but I decided I want 802.11ac … that project is still on hold for right now though.
802.11ac would rock with HWMP+. Mikrotik told me this.
usually we do not use wireless linux drivers - we make our own drivers - that
gives us possibilities to add our own features like Nstreme or Nv2.
So even if there is a linux driver available it doesn’t mean that we could add
support for the 802.11ac right away.
Thank you for your interest.
Regards,
Uldis
So I guess they dont want just the standard to be out. They want to make sure it works with nstreme and NV2 first before we can use it. NV2 rocks so I am fine with that. Would be nice to have a timestamp around when.
Thank you mikrotik for replying back so fast. I am very excited to get this standard going. I can just imagin the opportunity we could all have.
I just ordered a new backhaul, almost flipped when I tripped over a mini PCIe 802.11AC 3/3 Atheros card.
I almost ordered it…
I know. I wonder if they would still work. I remember even though mikrotik said they had no support for wireless N when it first came out. I was able to get the 802.11n working via command line. I wonder if they are going to do the same for 802.11ac? So we can try it out. I am sure the kernel already supports the 802.11ac in routeros 6.0. They just need put make it work with nv2 and nstreme.
@dallas
Please look here and read about the RB953GS-5HnT and then please read the comment from normis here and under the link normis was posting it was written from
Qualcomm:
By pairing the QCA9880 802.11ac radio with the QCA9558 802.11n SoC, networking OEMs can build cost-effective and power-efficient 802.11ac-enabled products that are capable of aggregate PHY rates of up to 1.7 Gbps. This dual-band platform will help drive the market transition to the latest Wi-Fi technology and enable customers to deliver home routers, carrier gateways and enterprise access points (APs) in time for the first wave of 802.11ac certification, which the Wi-Fi Alliance has scheduled for the first quarter of 2013.
The QCA9558 802.11n SoC is inside of the RB953GS-5HnT! Perhaps in one of the next WLAN APs it will be inserted!
Same boat here. We’ve been swapping out our backhauls with AirFiber as well. However, 90% of our backhauls are over 10 miles, some far as 40 miles. And my NV2 PtP’s are capping out big time. To the point, where I can’t wait any longer. Mikrotik is falling far behind, and quick. 802.11ac cards would be an instant fix. However, doesn’t sound like Mikrotik has even been trying.
What to do next?!?!? Licensed 6 or 11ghz. Very expensive, and probably a few months before something better comes out. I’ll be a beta tester too if Mikrotik has anything in the works!!
Yeah we keep on buying more airfibers. We also keep making them shorter distances too. Right now we are passing over 200mbps tcp of real world traffic. RB2011s are not keeping up so we moved to the rb1100ahx2. We want to use 802.11ac so we can use longer links at the same speed.
Sure your are right and I was looking once more around and all needed spare parts are
able to make it running, only the 802.11ac mini PCIe card with the Qualcomm-Atheros
QCA9880 802.11ac radio chip set is missing! It is a real pain.
WiBOX SA D4M5-90-17HVX = outdoor case & antenna for a 802.11ac compatible set up
_RB953GS-5HnT with the Qualcomm-Atheros QCA9558 802.11n SoC soldered on board
I am no hardware engineer or designer but is it so hard to solder mini PCIe card with a 802.11ac chip
under the own brand? And if they would do so, do you think that would be a real goal for the WISP customers,
what I mean do you really thing they would buy those 802.11ac cards and change their beloved RB433 equipment
to the new RB953 boards? I am not a WISP customer and can´t really answer this question, so I find it better to
ask this here in a smaller round because peoples could think I would kidding them. I really don´t know the problems
of those WISP set ups!
Thats a part of a wisp. As the customers grow. You have to upgrade the equipment. I climb 3-5 towers a day non stop. We grow 15-20 new customers a week. So as soon as I put it up. Its outdated. Thats why I am using airfiber. I just keep making shorter links. Which means more bandwidth.
Hi dallas did you realize it?
AC Support in RouterOS
Unfortunately it doesn’t work with AC cards yet, probably missing driver support.
We’ve tested it with Compex WLE900V5-23 (Qualcomm-Atheros QCA9880 Version 2).
Any update of 802.11ac support in RouterOS?.
I just found the acStation AC26 from COMPEX.
http://www.compex.com.sg/brochure/acwave_brochure.pdf
.. Some one try it yet?.
