where are password wifi security settings?
In WebFig v.6.7 I expected to be able to set the wifi password.
I couldn’t find the dialog. Am I missing something? I know it’s in “Quick set”… but wtf?
The password is set in the “security profile”
Regards,
Benny
Extra info: You first make or edit a security profile: wireless → security profiles
in your wireless interface you have selected the default profile so edit your password in the default security profile.
Use winbox not alone quick set this settings are not completed
Open winbox… see http://www.wirelessinfo.be/index.php/mikrotik/pages/secure
Go to “wireless” and click on “Security profiles”
Click on the blue cross.
Set password and wpa2 in
Done
At top of “wireless” page should be “security profiles” tab, create new (and set it in the interface configuration) or modify existing.
Thank you. UI could be better here.
You can do this in QuickSet tab, where it is much simpler. You are doing this in the “Advanced” interface now.
