Where can I download R11e-LTE firmware to manually apply an update as LTE interface is not working.
Deployed 3 RBSXTR&R11e-LTE devices. All worked originally. One then complained of the SIM not being inserted when LTE debugging turned on after it stopped working. The devices are quite remote.
(Edit: For clarity)
Have access via working units for remote management. Clear line of sight to cell mast approximately 400 meters away.
Working unit on same network:
-58 RSRP
-9 RSRQ
25 SINR
15 CIQ
I’d like to manually apply the latest firmware from a file as LTE modem refuses to initiate. To go from:
“MikroTik_CP_2.160.000_v010”
to
“MikroTik_CP_2.160.000_v012”
Speeds on the working units are below what I expected given the signal integrity but they are stable.
Fixed IP SIM on EE (one working) Band 3 20Mhz 18mbps down, 6mbps up
Flex IP SIM on VF Band 20 10Mhz 25Mbps down, 10mbps up.
Firmware update is the place I want to start troubleshooting. Any ideas appreciated. I’m a relatively new to MT hardware/ROS.
Devices are outdoors and this was one of my concerns.
