Where can I get previous RouterOS versions??
Hello.
I would like to know where I can get a RouterOS previous version for RB600 or if anyone has any stashed somewhere. I had ver 4.6 that was working well but, deleted from my pc and would like to reinstall that version to test if my RB600 performs better with it.
Thanks.
It’s recommended to use the latest one, so that if you have any issues, support doesn’t have to ask you then
If you insist, you can get them here:
http://download.mikrotik.rs/
