I can’t find the PCC option in my v3.6 as the picture shown below? How should I do?
What’s new in 3.24:
*) added per-connection-classifier matcher to firewall;
Do you mean add these commands which first following picture shown to the “terminal” in order to added per-connection-classifier matcher to firewall? but after I input these commands, it prompted shown on the second following picture.
You need to update to at least 3.24 for Mikrotik.
Version 3.6 is too old for that feature.
v3.6 older than v3.24?
Yes by a long shot.
v 3.6 is actually version 3.06, not 3.60
6 is actually less than 24 =)
it should be 3.06 but someone forget how versions are count.
should be? really? for example, show me vanilla kernel version 2.6.09. oh, is it 2.6.9? did they forget how versions are count too? ![]()
or maybe you are the only one who know that little secret? )))
Does anyone tell me how version be count? it confuses me much. It would be better if someone give me a sequence of all the Mikrotik version over version 3.X . Thanks.
X.Y where X increases with major numbers and Y increases with minor numbers. Both increase strictly so 3.24 is more recent than 3.15 is more recent than 3.6 is more recent than 3.0. In other words, 3.25 is the 25th minor release of major version 3.
oh,thanks,where can I download v3.24 now?
You can download the latest version via the download link on www.mikrotik.com. You can also easily find all this via google or the basic FAQs on the wiki.
guys, who counts versions like that?
Macos 10.4.1 up to 10.4.11 for example. Just like RouterOS.
1,2,3,4,5,6,7,8,9,10,11,12,13 …
