Back to Mikrotik after using Opnsense for while.
Newbie when it comes to firewall rules.
My understanding is, the fasttrack should be on top of the rules.
This is my firewall rules out of the box and the fasttrack is at number 8. Is this ok or I need to move it up? What else should be I be moving with it if I have to and does this need to be?
That’s default configuration ?
It has to be there.
If you add input rules, put them above FastTrack.
Rules #1-#5 are chain=input and fast track doesn’t apply. Then there is traffic which should not be fast tracked as it absolutely has to be processed before being router further, such as IPsec traffic. So your fattrack rule, being third in chain=forward, seems to be in the right spot.
Here’s my firewall output.
# oct/17/2021 13:31:58 by RouterOS 6.49
# software id = 5MZ7-RL5B
# model = RB760iGS
# serial number = E1XXXXXXXXX
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.4.10-192.168.4.200
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
set discover-interface-list=none
add address=192.168.4.1/24 comment=defconf interface=bridge network=\
192.168.4.0
/ip cloud
set update-time=no
/ip dhcp-client
add comment=defconf disabled=no interface=ether1 use-peer-dns=no \
use-peer-ntp=no
add address=192.168.4.0/24 comment=defconf dns-server=\
192.168.4.209,192.168.4.208 domain=clubamgg.com gateway=192.168.4.1 \
netmask=24
set servers=1.1.1.1,9.9.9.9
/ip dns static
add address=192.168.4.1 comment=defconf name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat dst-port=51820 in-interface=ether1 protocol=\
udp to-addresses=192.168.4.8 to-ports=51820
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=2200
set api disabled=yes
set winbox address=192.168.4.0/24
set api-ssl disabled=yes
/system clock
set time-zone-name=America/New_York
/system identity
set name=Router
/system note
set note="mehdi, clubamgg.com - Authorized administrators only. Access to this\
\_device is monitored."
/system ntp client
set enabled=yes primary-ntp=38.229.71.1 secondary-ntp=199.180.133.100 \
server-dns-names=\
0.pool.ntp.org,1.pool.ntp.org,2.pool.ntp.org,3.pool.ntp.or
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
Looks good the only things I would change
are
set allowed-interface-list=non
list=LAN (so as to enable access via winbox to the router on the LAN).
and this one as well…
list=LAN
