where is DDNS
I see in the manual that dns-update should be under tools with the advanced-tools package installed. I have advanced-tools installed, but cannot find DDNS?
What should I do (or where to look for it)?
Ekkas
/tool dns-update
Oh, I was just looking under WinBox… Found it under terminal. Will it work with the free DynDns.com ?
I’m not sure, however it works with changeip
http://wiki.mikrotik.com/wiki/Dynamic_DNS_Update_Script_for_ChangeIP.com
Probably with DynDns you can use another approach similar to EveryDns script
http://wiki.mikrotik.com/wiki/Dynamic_DNS_Update_Script_for_EveryDNS
