I’m quite new to Mikrotik but it seems there’s something wrong in my setup.
I have 2 CRS210-8G-2S+ connected with a fiber (SFP+).
When I test bandwith between the 2 I expect something like 10 Gb but here’s what I get :
Probably CPU can’t saturate 10Gbps link, however, those results do seem a little low.
What happens if you try 1G copper link instead?
A more realistic result will be obtained by testing with a device connected to each switch.
Nothing. Switching is done in hardware. Traffic generation is done in software.
The CPU isn’t very powerful and can’t generate anything like enough traffic to saturate the link, as you have seen. Is this a surprise?
You need to test through the device, not to it or from it.
Ok, thanks for the help.
It’s a surprise the CPU cant produce the bandwitdh …
I wanted to start from the beginning.
So, I’ve tried iperf from two physical servers connected each side of the CRSs.
iperf -c 192.168.0.17
Client connecting to 192.168.0.17, TCP port 5001
TCP window size: 20.7 KByte (default)
[ 3] local 192.168.0.63 port 59115 connected with 192.168.0.17 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0-10.0 sec 1.06 GBytes 910 Mbits/sec
Much better.
Tried with 6 in parallel from 2 servers and it’s ok too :
