Where is my error Cache option
Can you help me ,cache not work and i check the counter its 0
my setting
admin@MikroTik] ip firewall nat> print
0 chain=dstnat in-interface=internal protocol=tcp dst-port=80 action=redirect to-ports=8080
[admin@MikroTik] ip firewall mangle> print
0 chain=forward src-address=192.168.0.0/24 action=mark-connection new-connection-mark=users-con passthrough=yes
1 chain=forward connection-mark=users-con action=mark-packet new-packet-mark=users passthrough=yes
[admin@MikroTik] ip web-proxy> print
enabled: yes
src-address: 0.0.0.0
port: 3128
hostname: "proxy"
transparent-proxy: yes
parent-proxy: 0.0.0.0:0
cache-administrator: "webmaster"
max-object-size: 50240000KiB
cache-drive: system
max-cache-size: unlimited
max-ram-cache-size: unlimited
status: running
reserved-for-cache: 29707264KiB
reserved-for-ram-cache: 2048KiB
NAT rule ‘to-ports’ option should be equal to the proxy port. Your proxy port is 3128.
