Where Is Routing Test 3.23 For PPC?
Am I blind or is the routing-test package v3.23 missing from the PPC download. I am downloading the file all_packages-ppc-3.23.zip from MT.
Regards,
Malcolm
Test packages are not included in all_packages. You have to download them separately from the mikrotik download page.
Thanks for the reply. However if you click on the “view content” link for the above named file it clearly mentions routing-test as one of the contained packages. Can you see a separate link for routing-test-3.23-ppc.npk as I cannot?
Malcolm
Just to add - I did a bit of detective work and found it located at
http://66.228.113.58/routing-test-3.23-ppc.npk
But I still see no link for it. I just used the link for mpls-test and changed mpls → routing!!
test packages are now included in the routeros big package. I will make sure the separate links are returned though
