I’m trying setup a VPN in my mikrotik appliance, but for some reason the PPP option is not visible. See attached picture.
It is an RB450G with Level 5 license running RouterOS 6.1
Your help is appreciated.
Thank you
Thank you
go to system - packages. If it is greyed out simply enable it and reboot. If you cant find the ppp package, go to the mikrotik package download page and select mipsbe. There are a lot of packages but disabling the packages that you dont use can save some ram. You can try updating from the package page under system as well if your routerboard is connected to the internet.
To manually install/update packages, simply place the file in the root drive of your system partition and reboot.
Thank you!!!
