where is the restore button
I have a 411a with 3.11ROS and the restore button is not there anymore.
Will it be coming back or has it been moved?
OK,I can double click the file name and click restore, but I get this error: Couldn’t restore configuration - no file name(5)
Got it. system backup load name=backup
Found other posts on the problem and is seems that the restore only works in CLI.
In the current version this does appear to be the case.
Other posts say that it will be fixed in the next update.
is it neccessualy?build a new rout os is easily…do you think?
Uh, What?
he thinks that it’s easy to make a new router and make the configuration from scratch. which is probably true for simple routers, but there are some people with huge configurations, but to them I can recommend to also use the Export feature, so you always have a human-readable backup
Thanks for clearing that up. I had no idea what he was saying. LOL Maybe I should cancel my trip to China JJ :laughing:
Sorry about my bad english.But there has more chinese people can speak english good,not me.
Come to here just want learn more about the mikrotik’s .Cancel your trip to china is a badly idea,you will found it so beautiful than your think,trust me.:smiley: ```
thanks normis ^(^
