I would like to enable Webbox and allow some folks to access it for remote monitoring purposes. In addition, I would like to modify the menus if possible to limit the amount of information shown. At the least, I would like to change the image in the upper left corner.
Where are the Webbox files stored on MT? Is the entire page dynamic? I can’t seem to locate the html/cgi files. Please help. Thanks.
Sorry, GotNet is working an a large MT project and little things that get in my way (this is a good example) sometimes are like a hot poker in the eye. MT is good stuff but they keep it locked up tight.
You can see the source of the files while in webbox, but you can’t modify them.
The next major version (3.x) should have an API to allow 3rd party apps.
the page is mostly dynamic, and it is generated by the os, so it is absolutely impossible to modify it. like gotnet says, if you have some special needs, you will have to use the API
