I finally have some more time fiddling around with RouterOS on a CCR1009.
Goal is to get multi-WAN to work. From what I read is that PCC is the way to go but the only example in the manual is a bit thin for me: http://wiki.mikrotik.com/wiki/Manual:PCC as the explanation is very dense, likely expecting much more knowledge than I have now.
Regard me as a relative RouterOS noob.
I have multiple upstreams with different configurations and megabit speeds:
- ISP1 provides fiber with 50 down 50 up hands 1 static DHCP non-public IP address (as for now there is a NAT router in-between that does PPPoE, VoIP, ISDN/VoIP-bonding, etc)
- ISP2 provides fiber with 50 down 50 up hands out 6 fixed public IP addresses (same /29 subnet; ascending order) with a fixed gateway (they do PPPoE, I might later get rid of this one)
- ISP3 provides ADSL 10 down 2 up and hands 1 static DHCP non-public IP address (there is a NAT router in-between that does PPoE and NAT port forwarding). I will get rid of ISP3 within a year as speed is too slow compared to cost.
- ISP4 provides Cable 100 down 20 up hands out a non-static DHCP public IP address. I will get rid if ISP4 within about 6 months as speeds and latency are varying too much and not knowing when the dynamic IP changes is bad (it hardly does but when it does: havoc)
- LAN with non-public IP /24 subnet behind NAT with many port-forwards from the various ISP* provided addresses/ports to a bunch of locally running VMs/devices (think http(s), ssh, DNS, SMTP(s), etc)
- Wanting L2TP/IPSEC on all public IP-addresses
ISP1 and ISP2 have very low latency. ISP3 has big latency. ISP4 varies a lot.
I want to start with the above configuration step by step:
- Start with ISP2: it is already connected so I can test outgoing traffic from the router: that works; incoming doesn’t work well
- Get port-forwarding to work
- Add ISP1
- Add ISP3 and ISP4
- Migrate ISP1 PPPoE to the CCR1009
- Migrate ISP2 PPPoE to the CCR1009 as well
- Slowly ditch ISP4 and ISP3 (there is some stuff on the outside with hardcoded IP addresses that disallows me doing this sooner).
- Maybe add UPnP to the mix
Currently I have a TP-Link ER-5120 router that handles everything, but it’s a piece of crap for many reasons (DNS and DHCP are unreliable; it cannot handle incoming L2TP/IPSEC, PPTP or OpenVPN connections, more at https://wiert.me/2016/03/18/tp-link-er5120-limitations/) of which the latest is that many secure connections are unreliable (likely because they do multi-WAN all wrong) which for instance makes electronic banking and using the Google suite of services a pain.
A few questions up-front:
- for ISP1 - how to configure this on the CCR1009 so I won’t harm the upcoming multi-WAN steps
- for ISP2 - how to configure multiple public-IP addresses still going out the same gateway upon incoming traffic.
- for all - how to use the above mix of external addresses with PCC multi-wan setup
I’ve spread out the above over multiple phases for two reasons:
- I want to learn not only how a certain phase should be solved but also why
- They seem like the right chronological order to use (but if the order is wrong: feel free to explain why)
Any help is welcome, especially explanations with references on why a certain solution works.
Thanks for any help,
–jeroen
