And I do not want the answer: “It’s in the packages you find in the download section.”
I need to try to upgrade the firmware only through the console since the routerboard does not accept any upload of packages any more, not by ethernet, not by console and not by netinstall. Then the nand is empty because the initial part of running a install with netinstall works fine…, the formatting of the disk.
Need to try to get rb’s back with other firmware version to see if the transfer of files succeeds with that.
Or has anybody the last firmware on a single file?
If you are looking for the microcode (boot loader / firmware / BIOS) you can get it from the Routerboard site .(look at the product page for that board)
As for the original OS… ist make sure you have a backup of the config, nit just the backup file but the rules in a text export or in some form you can re-enter as some versions will not be able to restore form a muck newer version of the backup file…
You can obtain “back versions” by manipulating the URL in your bouser. IE hover over the single package file for the newest version of the file you want, then make a note of the url, type the url into your brouser modifying it to reflect the version you want.. press enter and the download will begin..
They don’t remove the old files, they just update the links to point to the newer versions… (At lease this was true in the past…) I think some “problem versions” may have been removed (oned that could crash the router on install) (This is a good thing..)
See some other treads on the forum.., I cannot upload any package to the router. Not with netinstall, ftp, winbox nothing.
By trying other firmware we just hope to get the routeboard back alive.
Al I can do is boot it over the ethernet from the bootserver and that´s were it all ends now. No upload of any file possible.
