I have a RB450G which is using the ‘default’ configuration working perfectly
The WAN side gets a public IPv4 address from my ISP
The LAN side is private DHCP / NAT
What I would like to do is route all traffic from hosts on the LAN side over a PPTP VPN
I have set up the PPP connection and it connects fine - I can see the public IP addresses in Winbox
All I need is a guide that tells me how to do the routing so that when I go out on the Internet with a LAN host, its IP address is reported as the VPN public IP not my ISP’s public ISP.
Many thanks in advance for your help
