Hi all,
I am new to Mikrotik. I have a new rb333 which had a 3.0rc6. I then upgraded it to 3.0rc8 using ‘routeros-powerpc-3.0rc8.npk’ . Now I want to downgrade to 3.0rc6. Where can I download the 3.0rc6?
Thanks,
apr
Edit:
There is a bug on the 3.0rc8 which don’t want WinXP’s ‘command prompt’ to expand. I mean when expanded, the cursor does not go to the bottom… the cursor always goes back and stays about 24 lines from the top. It is annoying that’s why I want to downgrade. FYI… I am using a Laptop with wide screen. Thanks.
