Where to order RB4011 iGS+RM andRB5009UG+S+IN routers in Ireland?
Not sure if the topic is in the right place but we are facing a problem. Urgently need some of both mentioned routers. The main reliable distributor in Ireland senetic.ie has no in stock need to require with no answer. Some other promoted distributors are just a joke or has only for their own needs. Around 10 years we work with Mikrotik routers and seems to be soon we will have to change the brand as cannot get Mikrotik gear.
Maybe someone knows where to get mentioned above or Mikrotik officials may bring in some light?
https://www.msdist.co.uk/mikrotik/rb4011-routers call
https://www.msdist.co.uk/mikrotik/rb5009-routers call
https://linitx.com/product/mikrotik-4011igs-10-port-router-rb4011igs+rm-routeros-l5-uk-psu/15597 awaiting restock :frowning:
https://linitx.com/product/mikrotik-5009ug+-compact-rackmount-9-port-router-rb5009ug+s+in-routeros-l5/16847 expected aug 26! :frowning:
https://www.amazon.co.uk/s?k=MikroTik+Router+RB4011&crid=3RYO72NKK5L4J&sprefix=mikrotik+router+rb401%2Caps%2C268&ref=nb_sb_noss_2
This is the problem “Call” , “Query” but then you call or query or then you ask so then you will have your awaiting stock answer is: “nobody knows, some day sooner or later” :confused:
So you should have asked the proper question: “Which sellerin Ireland has … on stock?” :slight_smile:
No hex S in Poland, CCR2004 PCiE offer survived one day … madness.
This isn’t an Ireland issue. It’s global. The wait time for networking gear from many, if not all, manufacturers is months and even then the backlog is so large you’ll find that they’re only able to ship out enough to cover a portion of their orders. Threatening to go to another company for your needs is pointless. You’ll struggle with all of them or pay 3 times what the gear is worth.
I have an RB4011 willing to lease for 100,000 Euros per year, or an Irish pot of gold :slight_smile:
Worldwide madness and not only related to electronics.
Steel and wood for construction, plastics, isolation, … all in HUGE shortage.
With leprechaun ?
Pssst … I suspect @anav doesn’t know about leprechaun particularities and that he’d be willing to accept it :wink: Let’s not spoil the joy for him.
Also ships international. Age 16 months. https://tweakers.net/aanbod/3040406/mikrotik-rb4011igs+5hacq2hnd-in.html
