Where/Who di I go to for RouterBoard hardware issues?
Subject says it all. I’m having issues with the NICs dropping off (according to the Interface traffic graphs in winbox). This is not a good thing. Routerboard 532A model. Ether1 is a management port, ether2 and ether3 are bridged. I’m doing traffic control on 2 and 3.
Also the Routerboard seems to be giving me an issue with bad communication to an HP Procurve switch. “Excessive Jabber” is the error.
-Wes Yates
always contact the seller of the item. they will look at the issue, and organize a replacement if necessary.
The reseller was WISP-Router Inc and I have not had a positive experience with them.
Are there any other users that seem to be having issues with the NICs/dropping packets? Are there any forums for hardware? What would be a good search term in the forums?
Thanks for the reply!
-Wes Yates
I don’t have similar experiences, but there is a RouterBoard (hardware) forum at http://forum.routerboard.com/ - perhaps take a peek there?
Best regards,
Christian Meis
contact mikrotik support if the reseller is not available.
Good vendor, but not very good support. Every time I ask them a question the answer is “I don’t know”… granted, I only call them to ask hard questions, because I can cover the easy ones on my own…
Thank you all for the replies and the RouterOS is one scarry good product! I am into traffic marking/queueing and the knowledge I have gain just by using RouterOS is amazing. Talk about an quantum leap in using HTB.
-Wes Yates
I would upgrade to 2.9.39 if you have not already.
It will only take a min and may fix your problem
Equis,
I am at 2.9.35, so that is a good suggestion. I will try that.
On another note, anyone know the admin email of the routerboard forum? I’m having difficulty logging in / registering.
Thanks.
E-mail to support@mikrotik.com
