Hello Having some problem to connect at high speed and have high throughput with an RB600 AP with rb52n Trying many clients
So I would like to know to which version mikrotik n drivers comply to:
Is there a difference between 4series and 5rc series?
Thank you
I think is final n. Same in 4.x and 5.xRC
I would hope for an answer from mikrotik (normis?)
LOL
The standard is now approved, and we support the standard. There are no versions, just one 802.11n standard. The OP probably means the Draft versions, but that’s old news. There are no more Drafts.
