Which are the best Hardware between BaseBox5 or RB435G
Hello guys,
I want to know which are the best hardware between BaseBox5(RB912UAG-5HPnD) or the RB435G with wireless cards for Point to Multipoint AP’s? I was Planning for 1 of RB435G with 3 sets of R52Hn Card with 3 sets rfelements mimo 5ghz 16db 120 degree sector for 360 coverage.
Or
3 Basebox5 separately with those sectors will be much better rather than RB435G with Three R52Hn cards?
Please advice me.
Regards…
I guess it all depends on price. If it doesn’t differ too much, I would go with the multiple boxes.
This gives you more CPU, network throughput, better granular failure (if one fails, 2 still work), etc. The downside is a bit more management, but that should be doable.
