Hello, can someone suggest routerboard of mikrotik to hendle about 80-100 users in extra case (in most case 60 users at the moment) (needed web proxy (browsing history of clients), dhcp server and maybe traffic management)? Thinking about RB/951G-2HnD is it good choice? WiFi not needed.
If Wifi is not needed, RB450G is also a good choice. Or RB750G
i have readed spec of RB450G. It more powerful, so the best choice for me. But if you look to future it haven’t mini pci…
So can someone say how many users it can handle with webproxy? Or how to calculate?
BTW thanks normis
a few hundred users will be ok with all the mentioned boards. RB2011 is also a worthy contender here.
RB2011. 64MB RAM is enough?
yes
Thanks for advice. My optinions i will stay at this decision:
MIKROTIK RB/2011UAS-RM RouterOS level 5
Advantages for me:
128 of RAM
LCD screen
includes power adaper
and big plus for RACK mount
but i don’t need routerOS level 5, i think for me enough level 3 or level 4
Level 3 has limits on number of users, if you need hundreds, you need Level5
