I run on an hAP ax³
- Pi-hole,
- Unbound.
I have tried installing other apps but that seems to make my router unstable.
What do you guys run on your routers ? Just curious.
I run on an hAP ax³
On a hAP ax3:
nginx
Trillium
I may switch from nginx to caddy now that it’s in the app list. I also plan on running Wallabag for the same reason.
I used to run Pi Hole but spent too much time ‘perfecting’ it that I switched to the built in adlist and added VLANS for devices I was trying to block
I have added a Beszel agent in order to monitor all of my infrastructure on the same tool.
