Which interfaces do I attach IP/VLAN/DHCP server to?
I have an AP (Groove A-2Hn) with wifi and one ethernet port. I’m trying to make 2 separate wifi networks, each on their own VLAN, each with their own DHCP server. But I'm getting confused about interfaces - and getting error messages. At a high level here’s what I’ve done:
  • defined a master WiFi interface (if-LINK), and a child WiFi interface (if-DMZ)
  • defined two VLAN's in Interface > VLAN (vlan-LINK and vlan-DMZ)
  • defined two IP’s, one for each wireless network
  • defined two DHCP servers, one for each wireless network
Questions:
  1. IP-interface: I have to assign each IP to an interface. Which interface do I attach each of these IP’s to? I can choose ether1, bridge1, the master wireless interface (if-LINK), the child wireless interface (if-DMZ), or the vlan interfaces (vlan-LINK or vlan-DMZ). I assumed the vlan-X interface.
  2. VLAN-interface: I have to assign each VLAN to an interface. Which interface do I attach each of these VLANs to? I can choose ether1, bridge1, the master wireless interface (if-LINK), the child wireless interface (if-DMZ), or the vlan interfaces (strangely I can attach my VLAN’s to vlan-X). I assumed that the VLANs should attached to the matching if-X. (But then the VLAN does not show as running)
  3. DHCP-interface: I have to assign each DCHP server to an interface. Which interface do I attach the DHCP servers to? When I add my LINK DHCP server to if-LINK (master WiFi interface), it complains "DHCP server can not run on a slave interface". (But it's NOT a slave). When I attach it to interface vlan-LINK it complains "interface not running".
I think I'm missing something conceptually...is there a way of looking at interfaces that will make all of the above make sense? I don’t understand to which interfaces I should attach each of the above three things.
(Pulling hair out)
Please do not start many topics onthe same subject.
Continue here: Help adding 2 SSID's+VLAN's to my existing AP
My other post is still ongoing…as I try to follow those instructions I’m getting confused about interfaces. So I started this topic on the more narrow interfaces topic. Once I understand this I will go back to trying to configure traffic flow across the VLANS. I didn’t want to send the other thread off on a tangent about interfaces.
Hope that’s ok…if not I will delete this and add to other thread.
Leave it now as it is but on the other hand users have to jump back and forth among different topics to collect all information. Part of a full answer is in one thread, another in the other and so on.
Ok - I have tried to merge this content into my other thread.
