wAP ax works fine in my use case and it’s smaller than cAP ax. Just put them in the corner and you covered the whole room.
If you can mount AP on the ceiling then I would go with cAP ax. If not then wAP ax could be a good choice. Ooorr… hAP ax2 for eg. could be used as AP as well. Smaller than ax3 but still provides good wireless
I don’t know my use case, but keeping in mind the directionality is important. The 7db gain is great, if that matches the use case.
I’ve never worked with a cAP, as I don’t have much call for ceiling mounted (I did use a bunch of Ubiquity LR6 ceiling mounted, and it showed me that ceiling mounted (when appropriate) has great advantages (i.e., not a lot things that could wind up touching or blocking the line of site to a ceiling mounted device).
Actually, that’s 2 separate gigabit ethernet ports.
It may seem strange but you will rarely get there.
That 2400Mbit/s is the physical data rate. Has little to do with the actual throughput (though higher data rate usually results in higher throughput).
Rule of thumb: roughly 50% of data rate is what you can maximum see as throughput.
But then the device needs to go somewhere else with what it received on that wifi channel. So it goes out via ethernet (usually).
And there you have a limit of Gb ethernet connections (which, let’s be honest) is PLENTY for an access point …
Really, I don’t understand why everyone wants the fastest and the biggest and most are using what ? 10% of it ?
What is the throughput you get with a 160Mhz channel and a good client?
With Hap ax3 (supports up to 80Mhz channel) I get with Ookla speedtest app on Samsung S23 886Mbps Down and 280Mbps up.
PC with intel AX211, so it supports 160Mhz-wide channels.
About 940-950Mbps using iperf3 to internal iperf container, which are normal values for a 1Gb link.
So the limit is the ethernet port, I guess.
