Do we have a buying guide here?
I’m trying to replace my TP-Link router and move to Mikrotik. My major activities are streaming and gaming. Thanks.
Unless you have specific requirements in number of ports, speed or mounting type, any MikroTik wifi device will be better.
This one should cover most peoples needs: https://mikrotik.com/product/hap_ac2
How many devices will you connect to the router? Routers often have less than eight ports (often four ports). If you need eight or more ports, a poe switch is beter choice.
Without knowing exact specification of what you want to achieve or you want to spend then I’d agree with Normis. That’s a great all rounder.
Confirm that.
