I am looking for help selecting the right mode for the MikroTik hAP Lite (RB941-2nd) that I just acquired to improve wireless signal on my network. If you could help me select the correct AP/bridge mode for my use case I would really appreciate it!
My primary (non MikroTik) router is located next to my modem. The router has a set-top box hardwired to it, all other devices are wireless. One Windows PC in a different room gets a poor/unstable signal due to thick walls, so I want to use the MikroTik as an access point (bridge?) just for that PC. I stream videos from that PC to the set-top box via Windows SMB sharing.
My goal is to:
improve internet access for the PC in the room with thick walls, and
to enable streaming large video files from the PC to the set-top box
In order for streaming to remain enabled, I need both the set-top box and the PC to be on the same LAN. I plan to disable WiFi on the laptop entirely, hardwire it to the MikroTik, and place the MikroTik just outside the room with thick walls.
Which mode do I need? There are so many in the Quick Set settings! CPE, PTP Bridge AP, PTP Bridge CPE, Wisp AP, Home AP, Basic AP, CAP, and it’s all very confusing. I am thankful for any help!
Documentation for Quickset is here: https://wiki.mikrotik.com/wiki/Manual:Quickset
It’s terrible though, and doesn’t tell you much.
Most people don’t bother with Quickset, because it usually makes a complete mess.
But if you want to persist, then CPE would appear to be the one you want (although I have never tried it).
Thanks sid5632. I don’t need to use Quickset. I need to use whatever settings are needed for my use case, if it’s not through Quickset, then via manual settings.
I really need someone to walk me through the settings though, as I spent several hours playing around with the settings with no success. It’s especially frustrating that you have to hard-reset the router after every attempt. Very amateur way to design a product.
If I read it right, he wants it to be a station to some other access point, not be an access point itself (which is what I presume HomeAP actually does - again I haven’t tried it).
I am confused. Why are you only thinking about wifi to the set top box?
Are you stating you have no ethernet wiring distribution in your location?
Go to your hardware store and find the longest drill bit you can find!!! Thick wall problem solved!!
It sounds like you would need to use a 2.4ghz frequency for thru thick wall tx with no guarantees especially if your area is already congested with wifi. Have you tried using electrical circuit for passing ethernet signal?
Is there any coax between the two room as MOCA connections are even better?
OP here, still looking for help with this. Since Mikrotik’s staff has pretty much abandoned this forum, can anyone recommend another forum with lots of traffic and knowledgeable users who can walk me through this setup step by step?
How does your PC get internet now?
If it is in another room, presumably it is wired to the current router?
Your entire logic is faulty if the PC is getting wifi now as its main supply. If the wireless signal to the PC is poor due to construction/walls etc, what makes you think that the reverse path will not suffer the same issues…
Since you have no ethernet wiring, and no coax wiring to the rooms your are SOL.
Your best solution is simple. Get a laptop to use to stream to your set top box and put it in the same physical location.
Or continue to attempt to stuff a noodle up a straw.
They are here and help out all what the can. Problem is that they/we can not understand your request.
Post a drawing of how you like it. Seeing thing visually help a lot.
I already described that in the original post. It gets WiFi, but the signal is weakened by thick walls. It’s fine for everyday use, but not for streaming HD video on the LAN.
The logic is not faulty, because if the Mikrotik can be hardwired to the PC in bridge or whatever mode, then it (the Mikrotik) can also be taken outside the room in the hallway and mounted on a wall, on top of furniture etc to avoid interference. That way only 1 wall will stand in the way instead of 2 or 3. The signal will become much stronger.
How in the world is that a solution? I need a stable internet connection in every room. Placing all computers in the living room does not solve anything.
Short version: The computer in the farthest room from the main router gets weak signal. I want to hardwire it to the Mikrotik and take Mikrotik outside the room to improve signal. All computers in the apartment need to be on the same LAN. The end.
