which one is the best ?
I have three servers, Which one is the best to install Mikrotik Router:
1- HP Proliant ML110
Chipset Intel® 3420 chipset
Processor Intel® Xeon® X3430 (2.40GHz/4-core/8MB/95W, 1333, Turbo 1/1/2/3) Processor
Processor Cache Integrated 8MB Intel® Smart Cache (Xeon 3400 series)
Installed Processors One-Quad Core Processor
Memory module & Size HP 4GB (2x2GB) Dual Rank x8 PC3-10600 (DDR3-1333) Unbuffered CAS-9 Memory Kit
Max Memory 16 GB (4 x 4 GB)
Storage Controller HP Embedded Smart Array B110i SATA RAID Controller (RAID 0/1/10)
(4 ports for HDD)
Storage Type Non-Hot Plug 3.5 ‘SATA’
Hard Drives 2 x 500GB SATA 7.2K LFF HDD
Expansion slots 4 Extended slots,with technology (PCIe & PCI), The bus width is X1,32bit,X4,& X16 respectively,connector width is X4,N/A,X8 & X16 respectively,Bus number is 16,48,32, & 1 respectivily,the form factor is full height,full length slot
Networking Embedded NC107i PCI Express Gigabit Ethernet Server Adapter
2-HP Proliant 150 G6
Chipset Intel® 5500 Chipset
Processor Intel® Xeon® E5506 (2.13GHz/4-core/4MB/80W, DDR3-800) Processor
Processor Cache Integrated 1 x 4MB level 3 cache (E5506, E5504, E5502 sequence)
Installed Processors Quad-Core Processors
Memory module & Size 2 GB, DDR3 Registered (RDIMM)
Storage Controller HP Smart Array P410I/Zero Memory RAID Controller (RAID 0,1std)
Storage Type Hot Plug 3.5 ‘SAS’ LFF
Hard Drives 1 x 300GB SAS 15K SAS HDD
Expansion slots Slot 1: 32b32bit/33MHz PCI 3.3V Slot, Slot 2: x8 PCI-Express Slot (Gen 1 x4 link), Slot 3: x8 PCI-Express Slot (Gen 2 x4 link), Slot 4: x16 PCI-Express Slot (Gen 2 x16 link), Slot 5: x8 PCI-Express Slot (Gen 2 x4 link)
Networking Embedded HP NC107i PCI Express Gigabit Server Adapter
3- Proliant DL 160 G6
Chipset Intel® 5520 Chipset
Processor Cache 4MB Level 3 cache
Installed Processors One Quad -Core Processors
Memory module & Size 2GB(1 x2GB) PC3-10600E-9 RDIMMS
Storage Controller HP Smart Array B110i SATA RAID
Storage Type Non Hot Plug 3.5 ‘SATA’
Hard Drives 1 X 250GB SATA 7.2K LFF HDD
Expansion slots Up to two available PCI Express 2.0 slots, Slot 1: full-length/full-height PCI-Express 2.0 x16 or Slot 1: half-length/full-height PCI-Express 2.0 x16, Slot 2: low-profile internal only PCI-Express 2.0 x8
Networking HP NC362i Integrated Dual Port Gigabit Server Adapter
Unless you wand to supply a small country with internet, none. All of them is much to big. :sunglasses:
