I recently changed my router for a hEX and noticed it has most packages enabled. Since I use it as a simple router, I was wondering if there are packages I could disable to save storage space. I am currently on 6.49.5 and will eventually move to 7.x (probably when 6.x is no longer updated and we are forced to move to 7.x) and may need some extra space.
The features I use are: DHCP server, DHCP client (on WAN side), routing, firewall, FastTrack
I don’t use IPv6, MPLS, PPP, wireless or hotspot (it’s not a wireless router, so the last 2 are useless). Can I safely disable those packages or will I break some dependencies if I do?
Currently, I have the following (default config):
