Hi. I have two Mikrotik routers in two different locations. They are behind a Cisco firewall and all ports (TCP and UDP) are closed on firewall. I want to open the required ports for a tunnel (IPIP or EoIP); Does anyone know what are these ports that I should open? Thanks
IPIP uses ip-encap protocol (4), EoIP uses GRE protocol (47)
so, if you’re blocking only tcp (6) and udp (17), then it won’t affect those tunnels
Hi Chupaka, I’ve been wrestling with this for 5 days now. I hope that you can help me out. How do I tell CISCO router to forward ip-encap protocol to my Mikrotik inside the network with a private IP of 192.168.230.246?
and why doesn’t it forward currently?..
