which power supply for sr5 or xr5
Which power supply is recommended for use with a 532a routerboard, ~125 feet of cat 5 and an sr5 or xr5 card? 18v power supply or a 48v power supply?
Amperage is far more important than voltage here. I run mine on 48 volts personally but there are many success stories of the 12-24 volt range but running a power supply rated for higher amperage.
