is there any small, home level RB, which supports attachment of the stronger antenna? I have a TP-Link here, which died, and would like to replace it with MT RB. But - the AP to connect to is on the roof above my flat, no cable here. TP-Link has 8dB antenna here. I can see RBs with only internal antennas? So - is there any supporting external antennas? Or do I need to build something around the bare bones RB and put it into a custom enclosure?
I need both - a CPE to connect to the AP placed one floor above my flat, as well as to provide local AP to other devices - ntb, smartphones, TV … I really miss SOHO Routerboards allowing to mount external antennas. Will go via some suggestions and see. Wonder how powerful the internal antenna is.
No, it does not. This has been asked and answered multiple times on this forum already. Those connector-looking things are factory test points, not antenna connectors.
