I’m running Internet Cafe and decide to. Hange router to Mikrotik finally.
Our cafe has 150 clients and 1Gbps fibre internet and needs to setup bandwidth control, game priority and anti hacking.
I have RB4011 and tested last year. But it was hacked like DDOS attack and changed to normal QoS router.
Is the RB4011 enough for 150 client PCs?
Can you recommend which model is enough for internet cafe?
CCR2004?
How about computer router? (i5 - 7400 , 16g ram?)
Can you recommend computer hardware spec if I go with PC?
RB4011 should be able to handle more than 150PCs and your bandwidth as well.
With regards to your DDoS issue, it’s possible that your ISP failed protection in their end, but nevertheless, if you configure properly your firewall rules, you could easily protect your network.
Better? you only have 150 clients and 1Gbits at most.
i5 is even overkill. RB4011 or RB5009 will serve your Internet Cafe without even running hot
Difficult to compare Intel i5 vs ARM64-chipset in detail.
