Which RouterBOARD for 100 users?
Hi I am new to RouterBOARD’s and I have just started work at a Company using a RB750 and they will have up to 100 users by the end of the year.
Now is the RB750 good enough the handle firewalling, VPN, Web filtering, WAN failover for up to 100 users?
Any advice will be gratefully accepted.
RB2011UAS-2HnD-IN would be a good upgrade, if you don’t want to jump to RB1100Hx2
So would you say that a RB750 isn’t suitable?
RB750 is a fine router, but for your growing requirements, I support an upgrade.
I’d use the 951G-2HnD.. If you’re not going to need the lvl5 license it’s practically the same board for half the price of 2011, just minus the extra, nearly useless 100mb ports and the sfp-port
