Hello all,
I’ve decided to implement MikroTik RouterBoards to manage VPN link between three sites (headquarter and branch offices).
I need also the possibility to have roadwarriors with the possibility to connect via VPN to the headquarter.
I can dedicate for a single routerboards a budet of 350/400 €.
If the CCR1009-8G-1S has a maximum kpps of 907 and considering the SHDSL and Fibre Optic in the B.O. #1 maybe I need something more powerfull?
And why the maximum kpps is misured on a such low number of filter rules?
I think that if I install a CCR1009-8G-1S for sue I will configure more than 25 firewal rules.
that number of 25 rules its only a point of comparison, ccr1009 will be enough surely for fiber even at gigabit speed, ccr1009 has the power to run a medium size ISP
For the idea to implement the HA on each site I was thinking to use two CCR1009-8G-1S or also two CCR1009-8G-1S-1S+.
Some suggestions?
Two CCR1009-8G-1S-1S+ are too oversized?
The final HA configuration wil be in master/backup or with both router active using some load balancing?
For IPSec VPN I would always go for a 1100AHx2 . CCRs choke at around 50-80 mbits range on IPSec whilst a AHx2 will give you at least 400 mbits or so minimum.
I’m not too keen on the mikrotiks for road warriors but you can make them work with some massaging. Keep aware of the gotchas on the mtk front like the Mikrotik requiring to be public facing as the Nat-t doesn’t seem to work on the server side.
What do I need to buy If I don not want to worry about to run more than one VPN server on a routerboard with EoIP and a good encryption plus NAT and rule filters with the configuratione of sites I worte in the first post?
