Hi
I have a RB133 and would like to know if it has sufficient CPU usage for the following
3 WDS connections to 3 different routers
+= 20 wireless clients
PPPOE server connected to a remote radius server to give the wireless clients internet
5 EOIP tunnels all terminating at the RB and then bridged together
So is my RB133 able to cope with the above?
Hai,
No, RB133 CPE’s designed. i think you will nice to sleep when you are using RB532 minimum.
You really think that I should upgrade?? I tried reading the manual to calculate which RB I would need but I got no where…
Is there anywhere were I can find how much CPU usage each service utilizes? thanks
normis
June 19, 2008, 9:48am
4
there is no way to determine CPU usage without exact configuration, and even then it depends on traffic kind and amount.
you should get a rb400 series because 133 is really meant as a CPE
Here’s few stupid questions
Does 433AH @800 MHz work better than some AMD/INTEL @3000 MHz? Is routerboard processor more efficient when talking about nstreaming?
In other words, if you had 3-4 wireless cards working @5Ghz + nstream, would you rather use rb or pc, and what would expected throughput be?
I would thing an intel pc would be better
