I need install point-to-point link on 2 buildings on 200 meters distance.
I want to buy SXT because it is easy install.
What model should to order:
SXTG 5HPacD 802.11ac, 16dBi, 28 degree antenna,
SXTG 5HPacD HG 802.11ac, 17dBi, 24 degree antenna,
or
SXTG 5HPacD SA 802.11ac, 13 dBi, 90 degree antenna ?
Thank you chechito for replay.
I want bay 802.11ac for max throughput. What it’s on 80Mhz channel?
I’ll set minimum TX power, but which antennas will be better: 24 degree or 90 degree?
