Yes, they are layer 3 ārouting switchesā. Basically routing functionality bolted on. The reason I was looking more at those is because that limitation that youāre pointing out (which does exist) is one that GENERALLY isnāt hit too often.I was more looking at the MPLS/VXLAN/QinQ/translational as features that can be done at line rate. Usually one would need one or the other, but not all at once. Now I am not pushing super hard to get those chipsets, Iām just more investigating and seeing if they are a fit. I personally would love to see line rate from Mikrotik. Or near line rate (which the Tile GX approach).
Something I was always hoping for was like a CRS226-24G-2S+RM chipset with the Tile GX for forwarding. Or CRS125-24G-1S-RM with Tile GX. Or even the smaller ones like the CRS210-8G-2S+IN.
In additional to as many high-speed ports as you can cram into the box either a line-card slot or just a bank of regular 1GB Ethernet ports can be extremely useful to designers and provide a high level of flexibility. Something like 6 - 12 x 1GB ports wouldnāt hurt the back-plane of the box significantly I imagine. Something I hated with the earlier Cisco ISRs and even somewhat today is the difficulty to obtain the number of ports necessary to do anything other than trunk down to a L2 switch below it if you are doing anything more than a typical edge router with NAT. This is already a strength with most of your devices shipping with 4+ ports.
However, I will add that ASIC limitations are no longer an issue for any of the newer whitebox switch gear running the Barefoot Tofino chip as the ASIC can be programmed on the fly with the P4 language. Barefoot is being put in switches that would have otherwise run a Trident 2+ chipset.
I assume that chip is a bit larger scale than Mikrotik is looking to go⦠given that it handles 65x the performance Mikrotik hinted towards in the initial post.
The question was on a router and around 100 Gbit throughput.
Iād think that would limit it basically to two QSFP-Ports (probably often used as āupstreamā). Iād further propose 6x SFP+ - ports and additional 8x 10G copper (10GBASE-T) for compatibility with existing (even GBit) connections. Iād liked an extra (GBit) management lan port and serial connection, too.
It probably makes sense to have (at least optional, if need be external) redundant power supplies as well.
Even if reduced to 4x SFP+, 4x 10GBase-T, 8x 1000Base-T (maybe even partly or all with PoE+) plus mgmt-LAN & serial would it make a great cloud router switch ā¦
Mike, Barefoot is looking to scale down as well as up. Itās a question I specifically asked them when I visited their corp HQ in January. Look for Barefoot going into smaller boxes in next 12 months.
I myself also talked about QSFP28, but as Normis mentioned, Mikrotik prepares for a 100Gbit/s router, not a terrabit one. Although I also want to build an inexpensive 100 Gbit/s core.
I would like to see more of a focus on the layer2 distribution side so it ties in with these new proposed routers. Otherwise we would need to pick other brands for L2 which we have been doing especially for SFP+ port density and POE. Stacking on the switches as well as the routers. More IPv6 support in ROS. No need for any LCDās. Removable dual power supplies.
Personally I do not need 10gb ethernet, but in the server/dc environment I can see the need.
Layer2 access:
24 SFP+ ports, dual PSU
24 SFP+ ports + 4 x QSFP, dual PSU
48 x 1Gbe + 2 x SFP+
24 x 10Gbe + 4 x QSFP
48 x 1Gbe POE at/af + 2 x SFP+
CCRās:
12 x SFP+ and 4 x 10Gbe combo ports
12 x SFP+ and 4 x QSFP
Please do a CLEAR separation between āenterpriseā routers, and SOHO routers. I think itās timeā¦
Enterprise Routers - PLEASE we are willing to pay, MAKE IT RELIABLE, make it PERFORM.
Interfaces, can be modular. 4 x 1GB, 4 x SPF, 2 x SFP+, 1 x QSFP+, etc⦠No need to have fixed ports. Same with power supplies, same with fans.
Just my 2c, but BIGGER routers means NOTHING when the CURRENT routers canāt perform either. Thereās numerous flaws on your āflagshipā CCR routers, which has little to no interest from MT to be fixed (PSUs, BGP, etc). I for one, wonāt even THINK about purchasing ābiggerā routers from MT when the existing routers are so unreliable and under performing.
I know this is probably not going to go over well, but Iām going to say it anyway: itās time for Mikrotik to have an Apple equivalent of āBack to the Macā; except the Mac is RouterOS. I donāt want to see another piece of hardware. I want to see a commitment to releasing RouterOS 7. All these different devices they are releasing, yeah.. they make sense for a small portion of your customers. Why not focus some effort on something that all your customers can benefit from? There are numerous wish lists on the forums talking about what weād all like to see in v7, so itās not worth re-iterating here.
Hopefully someone out there will see the logic in what Iām saying.
