Which USB-Ethernet adaptor can I use ?
After D-link DUB-E100 change their product and chip (from some reason)
I can’t use it on my routers
can someone give please which usb-eth can be used in the routers? I’m using RB411.
Thanks,
This one works, we tried it: http://store.apple.com/us/product/MC704ZM/A/apple-usb-ethernet-adapter
o.k.
do you know something less expansive? about ~15$
I need to buy much more then 1 so…
Is there any way to know if this one will work?
http://dx.com/p/usb-2-0-10-100mbps-rj45-lan-ethernet-network-adapter-dongle-34691
Thanks ,
they have not specified the chipset, and the reviews also don’t mention it. so no way of knowing 100%
try one
Thanks ,
I will try - and let people know if it’s work
Expansion issue
Which 1Gbps USB-Ethernet adaptor can I use ?
Apple USB 2.0 work fine, but its work 100Mbps and i need 1Gbps.
Which USB 3.0 1Gbps adapter will work with RouterOS?
Remember you also need USB3 support in RouterOS, and the only routerboard with it (RB3011) has not been released yet…
Sorry for replaying to old post i know, but just to mention in future if some one wondering. USB 2.0 works fine and for 1Gbps there is thunderbolt ethernet adapter, so it does not use any of usb ports, it use thunderbolt port on Apple macbook’s
