I’ve just discovered this new CCR2004-1G-2XS-PCIe.
Given its unusual form factor, which use case do you foresee for it ?
In which kind of host machine would you plus it in ?
Best regards
Best regards
putting it into a Linux/BSD box instead of a 10G NIC or putting it into a server used for virtualization (Proxmox or just Debian).
Let’s see, but I could imagine if I had a data center with more than just a few servers, I would be looking into a VXLAN overlay network with BGP signaling, or maybe MPLS to the host. Just for fun. ![]()
But seriously: using for routing and firewalling I could just have a single box doing everything for my home, no need for a separate FW box. Less energy and space wasted.
W
It’s very interesting product… especially if it’s really just 150e.
That’s about same as original synology 2x 5GbE card to put that in perspective on how cheap that is.
Perfect card for SSD NAS or VM server.
I’m sure there will be some clever uses of the router CPU as well.
There are only two things that would make it even better:
But overall it’s nice to see some new Mikrotik product that shows clever thinking “outside of the box” and trying something new.
Well, some of us are waiting for docker containers to be ready. This could be another aproach: you have a Server with lots of services (LibreNMS, Radius, IPERF…) and RouterOS directly connected to it. Instead of having things running inside RouterOS, you have your RouterOS side-by-side with them.
In an ISP, for example, you could have all your services in one BOX: your server box.
Having a PoE-IN Gigabit port, instead of non-PoE one, would be awesome.
It might even solve some booting issues and bring dual power sources (one from PoE, one from PCIe slot).
This card has a 29W power consumption.
This would require 802.3at or 802.3bt to be safe.
Some use cases:
Fabric Termination NIC
CCR2004-1G-2XS-PCIe connects to Leaf/Spine L3 switching
eVPN support to exchange L2/L3 Forwarding Database via BGP with VXLAN and MPLS as options for the fabric overlay
Bridge from eVPN “instances” to vlans/interfaces on the Host facing NIC
Would require FastPath VXLAN, FastPath MPLS/PW and eVPN support to be added to RouterOS (should be on the v7 roadmap regardless)
Fabric Connectivity is off-loaded from the Host CPU
Firewall/Router for Virtual Machines
CCR2004-1G-2XS-PCIe connects to upstream networks
vlans/interfaces on the Host facing NIC terminate L3 on the CCR2004 (could even be into VRF’s)
Routing/Firewalling is performed on the CCR2004 and off-loaded from the Host CPU
25Gbit “pass-thru” NIC for the Host.
How would a Linux host + CCR2004 card combo compare to a single server host with Open vSwitch ?
The first question I had when I saw that fascinating product in the latest newsletter was how it compares to putting a dumb 2x SFP28 card into the machine and attaching a CHR to it? With hardware virtualization, the PCIe card can be dedicated to the VM, so the overhead should be negligible. Given that, why would you bother putting a captive copy of RouterOS onto the card itself?
Someone up-thread mentioned taking the load off the host CPU, but surely the host CPU is hugely more capable. This CCR2004-on-a-card is basically a Raspberry Pi 4 with better Ethernet I/O. Powerful, yes, but not Xeon powerful.
EDIT: Minor factual errors. Question stands regardless.
https://www.servethehome.com/mikrotik-ccr2004-1g-2xs-pcie-is-a-2x-sfp28-25gbe-router-on-a-pcie-card/
i think is not about a host x86 CPU not being capable of io tasks
its about offloading this tasks to free up CPU host resources to improve overall system performance, and potentially get better performance
most NICs already offload some io tasks even on a PC, you can try disabling this offloads then move 1gbit of traffic to see how much CPU you was saving thanks to offloading, you will surprise.
smart NICs go one step ahead offloading more io and networking tasks
then we see DPUs going even further in this field
For example on a virtual machine server, io and network offloading can improve the overall performance off all virtual machines leaving almost all CPU resourses free to serve virtual machines
Not a trivial advantage in times when you want to get the most performance of the platform, cpu cores, space and power used by the system
The question with this MikroTik iniciative is to know in wich league CCR2004-1G-2XS-PCIe fits
time will say it
I wonder how flexible this PCIe interface is, can it be completely customized? If yes, then it could be changed from ethernet to something else.
Something like Infiniband, have shared memory available to host and let the controller do all the heavy packet lifting to synchronize it across network.
Just another crazy idea…
I’m also thinking about his usage as a router inside the virtualization servers to enable an independent and practical way of connecting “distant” services with VM’s using some kind of tunnels or VPNs to routers.
I have some questions about the product that aren’t explicit in the product page:
Last I have a suggestion for a future revision of the card/router …
To enable independent operation between the host and the “router” it would be nice to have and option of providing external power to it via a common barrel jack like in the other MT products.
This will also solve the problem of some fast hosts booting faster than the router and needing to wait for it.
regards!
Some of what you want is covered in the announcement video: PCIe 3.0, 8x.
You’ve never done any electrical engineering, have you?
If the MikroTik EEs could somehow assure themselves that no one would ever plug in anything but a manufacturer-supplied or specified aftermarket power supply — e.g. by use of a nonstandard connector, not the standard barrel connector that you want — they could get around the problem of dueling grounds by use of a more expensive isolated power supply.
One does not need to monitor this forum for long to see that many users would lash up something locally and plug it in, expecting the isolation of the Ethernet outputs to save them from their folly. That won’t work in this case, giving a pretty good chance of blowing up the computer’s power subsystem.
It’s possible to make it work with any random external PSU as the standalone products do, but far from trivial. I expect that you doubt this, so riddle me this, Batman: name another PCIe card that has this feature.
Isolated DC/DC converters exist exactly for this reason. And they are pretty much standard when it comes to proper (active, not cheap passive) POE equipment.
Sure, you can move the isolation from the wall wart into the card itself, increasing its cost and the heat burden it puts on that big old fan you see on the current model. If you expect it to take the wide inputs of current MT equipment (e.g. 12-57V as on some things) then it needs to be a step-up/step-down type, further increasing cost over the far more common step-down type.
Having done so, you still have to work out how to avoid back-feeding power into the bus via the card-edge connectors, blowing adjacent cards and mobo chips up from being driven “backwards” with the rest of the system powered off.
TANSTAAFL.
A big part of the smartnic appeal, today, is to do router-on-the-host type operations without giving up any of the host cores. I have 128 cores in the box, and I’d like to be able to sell all of them. They’re capable and pricey. For all intents and purposes, the four cores in the NIC are “free”, assuming the thing doesn’t have an obscene power budget.
Well, we are running a CHR as a VM in an ESXi host where we initially also had it do the management routing, and that is a pain.
You cannot even install ESXi updates as this requires bringing the server in maintenance mode, shutting down the CHR, and losing the access.
Therefore we installed a leftover RB2011 just for management (connected to a server ethernet port for vmkernel and to the ILO port).
I could imagine installing this new device, connecting the SFP28 to internet, the ethernet port to the ILO, and doing all routing on the card, even for management.
However, it is unclear to me if the RouterOS would restart when the server is rebooted. Or even if it could be kept alive when the server is “powered off” (i.e. powered by standby power).
Really attractive for host routing setups.
Currently, I support too many hypervisors, so my questions lie with "are there drivers on the way for VMware and Hyper-V/Windows? Xen boxes probably mean backporting, which leaves the current described state as basically a NIC for KVM boxes, container hosts, and firewalls.
Probably buy a couple for firewall testing, but given current shortages, could probably be convinced to standardize on the things if the drivers were there.
Not planned at the moment. No Windows/HYPER-V native support. Possible, the 3 of 4 PCIe emulated NICs can be passed to a HYPER-V VM (Linux/FreBSD) via DDA but SR-IOV is required for that. Otherwise - no way at the moment.
Though, it should work on ESXi 5/6 with custom VMKLinux drivers. Doesn’t work on ESXi 7.
If the rumored price of about 210€ turns out to be true, it is even a very good offer if it is just used as a “normal” 2x SFP28 NIC in pass-through mode for Linux servers.
