Good evening !
I copied scripts from both devices.
ATL 5G
2025-09-08 21:11:00 by RouterOS 7.19.4
software id = xxxxxx
model = ATLGM
serial number = xxxxx
add name=bridge1
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add apn=internet.tele2.ee name=internet.tele2.ee use-network-apn=yes
/interface lte
set [ find default-name=lte1 ] allow-roaming=no apn-profiles=
internet.tele2.ee band="" nr-band=""
add name=default-dhcp ranges=192.168.188.10-192.168.188.254
add address-pool=default-dhcp disabled=yes interface=bridge1 name=defconf
/port
set 0 name=serial0
/queue type
add fq-codel-ecn=no kind=fq-codel name=fq-codel-ethernet-default
/queue interface
set ether1 queue=fq-codel-ethernet-default
add comment=defconf interface=lte1 list=WAN
add address=192.168.88.30/24 comment=defconf interface=bridge1 network=
192.168.88.0
add address=0.0.0.0/24 comment=defconf dns-server=0.0.0.0 gateway=0.0.0.0
netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.30 comment=defconf name=router.lan type=A
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
established,related,untracked
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes
/ip hotspot profile
/ip upnp interfaces
add interface=bridge1 type=internal
add interface=lte1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute"
dst-port=33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6"
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1"
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
!LAN
/routing settings
set single-process=yes
/system clock
set time-zone-name=Europe/Tallinn
2025-09-05 23:47:26 by RouterOS 7.20rc1
software id = xxx
model = H53UiG-5HaxQ2HaxQ
serial number = xxx
add admin-mac=xxxxxxxxxxx auto-mac=no comment=defconf name=bridge
set [ find default-name=ether5 ] name="ATL 5G"
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac
configuration.country=Estonia .mode=ap .ssid=MikroTik-5G disabled=no
security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac
configuration.country=Estonia .mode=ap .ssid=MikroTik-2G disabled=no
/interface ethernet switch
set 0 cpu-flow-control=yes
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface="ATL 5G"
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
/interface ovpn-server server
add mac-address=FE:E1:70:AF:A5:AE name=ovpn-server1
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
add address=192.168.88.30/28 interface=ether1 network=192.168.88.16
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=
192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
invalid
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
/ip ipsec profile
invalid
icmpv6
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
ipsec-ah
ipsec-esp
!LAN
/system clock
/system package update
set channel=testing
/system routerboard wps-button
set enabled=yes on-event=wps-accept
/system script
add comment=defconf dont-require-permissions=no name=wps-accept owner=*sys
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon
source="\r
\n :foreach iface in=[/interface/wifi find where (configuration.mode="a
p" && disabled=no)] do={\r
\n /interface/wifi wps-push-button $iface;}\r
\n "
/tool mac-server
/tool mac-server mac-winbox
