Which Wireless to choose
I’ve been using Mikrotik for around 2 years now, mostly for Hotspot and VPN/Firewall stuff but now need to install a p2mp wireless network.
I want to install 1 Omni-tik and 4 SXT that connect to it. The distance between the links is between 30-50 meters.
Which is the best wireless protocol to use and why?
What are the benefiets with going 802.11, NV2 or Nsteme and why?
I heard a lot of people complaining about disconnects etc, I just want something stable.
you can go with either of them, nstreme and nv2 is going to be faster than vanilla 802.11, and if you are using only RouterOS wifi clients, that is good option to choose.
the fastest of all three would be NV2 in normal conditions.
What are normal conditions?
My thoughts exactly
He meant “most situations”
