please have a look in the image file of Network Scenario,
I can use all server from outside (http://www.erp.xxxx.com) by using the port forwarding from main router (RB 1100 AH) but when i access the server from local (http://10.11.35.61) it access the Proxy server, because i use the Mikrotik PC based router as a web proxy as transparent. also i can’t access the server by giving the host name (http://www.erp.xxxx.com) from local PC. I have to access the server by giving the local IP address (http://10.11.35.61). can any body give me a solution regarding this issue.
Do you run internal dns ? One way would be to add a records for the dns name with the internal ip.
The other way would be to.create hairpin nat
Sent from my GT-I9100 using Tapatalk 2
No I didn’t have DNS with internal record,
I just use third party DNS (4.2.2.2 | 8.8.8.![]()
maybe move clients to the routerboard dns which then uses google dns, then you can add records.
here’s the hairpin nat: http://wiki.mikrotik.com/wiki/Hairpin_NAT
