Hi
Do you know how or who can help me with drilling 2 additional opening in my access point enclosure? Here is the enclosure.: http://www.allrfcables.com/product_info.php?cPath=53&products_id=89
P.S
I already have those 3 enclosures with 2 openings only.
thanks
vik1988
December 28, 2010, 5:26am
2
Any metal job worker can do that. Search near you. tell him about the diameter of circle he will do that with tools.
Thx
Can you be more specific? “metal trade worker” is a broad statement, don’t you think so?
thx
normis
December 28, 2010, 7:30am
4
I don’t think so Any person with a drill and little experience in using it, could do the job.
it is not as simple as it seams, as long you have don’t it, know how to do it.
what tools, i need , it has to be threaded inside, what tools, etc.
I do this to about every case I own for N type antenna connectors. I use a 1/4" drill bit to start the holes, and a Unibit to enlarge it to the correct size. I don’t thread the holes tho.
http://www.irwin.com/tools/browse/drill-bits/unibit-step-drills
vik1988
December 28, 2010, 3:34pm
7
home depot has those bits?
thx tho
If that response/question was aimed at both of us, then my answer is “yes, you can get the bits I use at Home Depot”. However, I bought mine at Ace Hardware.
I think the solution offered by vic1988 is a bit overkill on the equipment required to do this.
