my nat loopback does not work
to get it working, i need to remove the
in-interface-list=WAN
from my nat rule.
why ? i mean, even from inside, if i try to open the webpage on my server using domain name, the request come from my WAN right ? so why putting WAN break it ?
thanks for this very short answer.
so , let say i need to put a in interface (which is not the case i suppose for me currently), how to make nat loopback works ?
Interesting, you don’t set a dst-address as you srcnat rule.
all example si see put the local server ip address in this rule. i suppose your rule is then valid for the whole network ?
in my case, your solution works fine with 1 server, not with the other
i have 3 WAN access
and i have these routes:
[admin@RouterOS] > ip route print
Flags: D - DYNAMIC; A - ACTIVE; c, s, d, v, y - BGP-MPLS-VPN
Columns: DST-ADDRESS, GATEWAY, DISTANCE
# DST-ADDRESS GATEWAY DISTANCE
D v 0.0.0.0/0 pppoe-orange 3
DAd 0.0.0.0/0 xxx.xxx.xxx.xxx 2
0 s 0.0.0.0/0 10.0.0.1 10
DAc 10.0.0.0/24 ether3 Backup_4G 0
DAc 10.10.10.0/24 bridge 0
DAc xxx.xxx.xxx.xxx/24 ether2 Fibre_Free 0
DAc 192.168.11.0/24 bridge 0
DAc yyy.yyy.yyy.yyy/32 pppoe-orange 0
1 As 0.0.0.0/0 pppoe-orange 1
2 As 0.0.0.0/0 ether2 Fibre_Free 1
3 As 0.0.0.0/0 ether3 Backup_4G 1
routes with metric 1 are used by some specific rules in the routing rule settings.
so by default, everything go though route with metric 2.
but 1 server as a specific rule, so the route used is the pppoe-orange with metric 1.
[admin@RouterOS] > routing/rule/print
Flags: X - disabled, I - inactive
0 src-address=192.168.11.100/32 action=lookup table=VersOrange
for this server, the hairpinning rule does not work. i don’t understand why.
