On our 1 network we have RB493AH->Airgrid M5->Airgrid M5->RB433AH
Airgrid is Ubiquity ‘mimo’ (but can only be 1 pol since it’s a grid) integrated solution.
There we get 63Mbps TCP (From 493 to 433 test).
Airgrid:
Today we set up a Mikrotik link, about same distance (±8km) with great LOS, good fresnel, etc. (Massive) 32dBi dual-pol dishes, R52n cards at both ends. 1m LMR400 cable runs.
We get marginally better speed with 70Mbps! Massive antennas, tweaking configs, etc. NStreme enabled, .
Mikrotik:
Airgrid does not even have nStream, it’s only 1 pol and it’s almost as fast and you just plug and play to get that speed. (Using 40Mhz)
What can I be missing here? Signal strength is -65, SNR 52dB.
2 R name=“ToHDP” mtu=1500 mac-address=00:0C:42:61:2C:EC arp=enabled disable-running-check=no interface-type=Atheros 11N
radio-name=“000C42612CEC” mode=ap-bridge ssid=“TWP2P12” area=“” frequency-mode=manual-txpower
country=no_country_set antenna-gain=0 frequency=5320 band=5ghz-onlyn scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps
basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default
periodic-calibration=disabled periodic-calibration-interval=60 dfs-mode=none wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=enabled hide-ssid=no
security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=short compression=no
allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0,1,2,3,4,5,6,7
ht-guard-interval=any ht-extension-channel=below-control
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-
15
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-15
ht-txchains=0,1 ht-rxchains=0,1 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 hw-retries=7 frame-lifetime=0
adaptive-noise-immunity=none hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0
frequency-offset=0
2 interface-type=Atheros 11N
chip-info=“mac:0x80/0x2, phy:0xd0, a5:0xc0, a2:0x0, eeprom:0x0”
pci-info=“00:12.0” capabilities=tx-power-control,ack-timeout-control,
virtual-ap,alignment-mode,scanning,
nstreme,sniffing,power-channel,ht40-a,
ht40-g,wmm,spectral-scan
default-periodic-calibration=enabled
supported-bands=2ghz-b,5ghz,2ghz-g,5ghz-10mhz,5ghz-5mhz,2ghz-10mhz,2ghz-
5mhz,5ghz-11n,2ghz-11n
2ghz-b-channels=2412:0,2417:0,2422:0,2427:0,2432:0,2437:0,2442:0,2447:0,
2452:0,2457:0,2462:0
5ghz-channels=5180:0,5185:0,5190:0,5195:0,5200:0,5205:0,5210:0,5215:0,
5220:0,5225:0,5230:0,5235:0,5240:0,5260:0,5265:0,5270:0,
5275:0,5280:0,5285:0,5290:0,5295:0,5300:0,5305:0,5310:0,
5315:0,5320:0,5745:0,5750:0,5755:0,5760:0,5765:0,5770:0,
5775:0,5780:0,5785:0,5790:0,5795:0,5800:0,5805:0,5810:0,
5815:0,5820:0,5825:0
2ghz-g-channels=2412:0,2417:0,2422:0,2427:0,2432:0,2437:0,2442:0,2447:0,
5ghz-10mhz-power-channels=5175:0,5180:0,5185:0,5190:0,5195:0,5200:0,
5205:0,5210:0,5215:0,5220:0,5225:0,5230:0,
5235:0,5240:0,5245:0,5255:0,5260:0,5265:0,
5270:0,5275:0,5280:0,5285:0,5290:0,5295:0,
5300:0,5305:0,5310:0,5315:0,5320:0,5325:0,
5740:0,5745:0,5750:0,5755:0,5760:0,5765:0,
5770:0,5775:0,5780:0,5785:0,5790:0,5795:0,
5800:0,5805:0,5810:0,5815:0,5820:0,5825:0,
5830:0
5ghz-5mhz-power-channels=5175:0,5180:0,5185:0,5190:0,5195:0,5200:0,5205:0,
5210:0,5215:0,5220:0,5225:0,5230:0,5235:0,5240:0,
5245:0,5255:0,5260:0,5265:0,5270:0,5275:0,5280:0,
5285:0,5290:0,5295:0,5300:0,5305:0,5310:0,5315:0,
5320:0,5325:0,5740:0,5745:0,5750:0,5755:0,5760:0,
5765:0,5770:0,5775:0,5780:0,5785:0,5790:0,5795:0,
5800:0,5805:0,5810:0,5815:0,5820:0,5825:0,5830:0
2ghz-10mhz-power-channels=2412:0,2417:0,2422:0,2427:0,2432:0,2437:0,
2442:0,2447:0,2452:0,2457:0,2462:0
2ghz-5mhz-power-channels=2412:0,2417:0,2422:0,2427:0,2432:0,2437:0,2442:0,
5ghz-11n-channels=5180:0,5185:0,5190:0,5195:0,5200:0,5205:0,5210:0,5215:0,
2ghz-11n-channels=2412:0,2417:0,2422:0,2427:0,2432:0,2437:0,2442:0,2447:0,
ht-chains=0:chain0,1:chain1
2 name=“ToHDP” enable-nstreme=yes enable-polling=yes disable-csma=no framer-policy=best-fit framer-limit=3998
8 interface=ToHDP radio-name=“000C4265B693” mac-address=00:0C:42:65:B6:93 ap=no wds=no rx-rate=“243.0Mbps-HT”
tx-rate=“117.0Mbps-HT” packets=6933102,2928231 bytes=3748849318,1672769648 frames=3789490,2097049
frame-bytes=3777477724,1672871590 hw-frames=5612686,39238232 hw-frame-bytes=322965767,3466293947
tx-frames-timed-out=0 uptime=4h35m41s last-activity=0s signal-strength=-66dBm@6Mbps signal-to-noise=51dB
strength-at-rates=-66dBm@6Mbps 0s,-65dBm@9Mbps 4h35m39s980ms,-64dBm@12Mbps 4h35m39s830ms,-65dBm@18Mbps 4h35m39s350ms,-
65dBm@24Mbps 4h35m39s40ms,-66dBm@36Mbps 4h35m38s360ms,-67dBm@48Mbps 4h33m38s790ms,-69dBm@54Mbps
4h33m32s390ms,-66dBm@HT20-4 4h23m39s370ms,-65dBm@HT20-5 4h18m38s900ms,-67dBm@HT20-6 4h18m8s390ms,-
72dBm@HT20-7 4h18m8s270ms,-72dBm@HT40-4 10m24s170ms,-70dBm@HT40-5 7m20s80ms,-70dBm@HT40-6 0s,-
75dBm@HT40-7 23m51s560ms
tx-signal-strength=-66dBm tx-ccq=95% rx-ccq=97% p-throughput=90584 nstreme=yes framing-mode=best-fit
framing-limit=3998 routeros-version=“4.16” last-ip=10.1.6.26 802.1x-port-enabled=yes compression=no wmm-enabled=yes
