Follow you can see my another mpls test network.
| PC1 ROSv 3.28 | | MT1 rb411 ROS 3.28 |
| eth0 MTU 1522 | | ether MTU 1522 |
| 10.1.1.1/24 | | 10.1.1.2/24 |
| lobridge | 100TX | lobridge |
| 9.9.9.1/32 eth0| ---------------| 9.9.9.2/32 |
| vpls0 ip 1.1.1.1/24 | | wlan 10.10.2.1/23 |
| to 9.9.9.3 | | MTU 1522 |
/ WLAN 5 GHz
| MT2 rb411 ROS 3.28 |
| WLAN MTU 1522 |
| 10.10.2.2/24 |
| lobridge |
| 9.9.9.3/32 |
| ether\ |
| bridge0 |
| vpls0/ ip 1.1.1.2/24|
| to |
| 9.9.9.1 |
When on PC1 start Bandwidth Test with udp 1500 bytes packages to 9.9.9.3 everything works well until in /mpls interfaces I've got:
INTERFACE MPLS-MTU
0 all 1508
after I replace "all" with ether, 1500 bytes packages stops leaving router. Maximum packeges size with reach the 1.1.1.2 is 1492 bytes. Even after I'll add all PC1's interfaces including lobridge to /mpls interfaces, packeges bigger then 1492 bytes does want to reach second end of vpls tunel.
Why ?
Another question:
How can I check is there fragmented packet during mpls/vpls label add
