Why are my posts being deleted from this forum?
I have posted two different threads in the scripting forum this week and both seem to have been deleted. Not sure if I am doing something against rules but no mod has been in contact to advise.
This forum is practically not censored (it is not in UBNT forums).
Obviously something went wrong, but without knowing the content no one will be able to give an answer here.
I recommend reading the rules and contacting the administration to find out.
Good luck with contacting an administrator. Messaging is switched off again.
It could be that your posting got reported and they are deleted…manually or “automatic”.
ps. you posted this in scripting and that is not right place post this.
I posted in scripting because that’s the forum the posts were removed from.
Looking through the moderator logs, I see that the only removed posts were self removed. Including the post deleted on the 26th of November, and after that, the ones you removed in September. Perhaps there was a misclick, but I don’t see a moderator willfully deleting your posts.
Ok, thanks for looking into it. Must not have posted when I clicked submit.
Yes but it was also in the Mikrotik and there are other sections in that forum more suitable for those kind of questions.
i got my post removed too
Your fault, on moderators log I do not see any of your post removed.
If you click only on “Preview” the post is not published until you do not press “Submit”!!!..
