Why connection bytes field is not active?
Hello!
I try to mark packets in connection, all settings I’m doing via winbox. Fields connection bytes and connection rate is not active for editing. What it can be connected with?
These are only selectable when you select a protocol that supports the concept of connections and
that the router knows how to track.
Thanks, it works!
