Why CRS125-24G-1S in Winbox Meue
Hi, I use some Mikrotik Device
the RB2011UAS-2HnD Device same the Winbox menu command(System-ntp client) and terminal
But, CRS125-24G-1S is Different
Show the Winbox : System->SNTP Client
Show the terminal : /system ntp client
Why is different?
I think CRS Device should be the same meun name the RB2011 device(or another device)
Because it May not be confusing.
Hi!
This is because you have different packages installed
On RB2011 you have a separate NTP package installed that override the SNTP package included in
the default package.
You can install the default package and as packages as you like OR install all separate packages
Hope it helps…
RGDS
Jörgen
Thanks a lot
After NTP Packages install for CRS model,
Name is same in RB2011 meun
